Rear drive pulley ?
Old 02-11-2012 | 09:44 AM
Bryce05's Avatar
Bryce05
Default Rear drive pulley ?
I have a 05 softail that I'm doing a 200 tire conversion on this spring, I'll be using a 06 rear pulley from a 200mm wheel. I know my current pulley is 70 tooth and I think the 06 is 65? Is the front pulley that same size on the 05,06-07? Will the 65 tooth give me more low end? Thanks
Old 02-11-2012 | 10:19 AM
SprungDave's Avatar
SprungDave
Can't speak to the front pulley size, or if your same belt can work with the smaller rear pulley (if there is enough rearward play to tension the belt with a smaller pulley), but I can say that IF it all goes together, you will have less low-end grunt, but you will have lower RPM at highway speed.
Old 02-11-2012 | 10:54 AM
RHillbilly's Avatar
RHillbilly
The 65 will give more top end they make a 70 tooth sprocket
Old 02-11-2012 | 12:09 PM
Bryce05's Avatar
Bryce05
Ok that's good I'd rather have the low end. What's the whith of the 06 pulley 1" or 1 1/8"
Old 02-11-2012 | 01:05 PM
oct1949's Avatar
oct1949
From what I can find, it looks like they changed in 2007 along with the 96'er and six speed, to 32 tooth front, 66 tooth by 1" wide rear pully.
1995-2006 softails used a 32 tooth front, 70 x 1 1/8 rear pulley.
So thinking the 06 Ur getting should have the 70 unless someone changed it out.
Again as said above, if U now have a 70 and go to a 65 U'll lose acceleration down low and U'll be running less RPMS at same speed on hiway.
Its like a car with 308 gears (65Tooth pully) vs one with 411's (70Tooth)..
giacomo56
06-24-2015 05:24 PM
badger3x
02-19-2013 02:35 PM
gavdar
05-18-2011 05:17 AM
luvtoride
10-09-2010 05:58 PM
rotorcrazy
04-10-2009 04:51 PM
Quick Reply: Rear drive pulley ?
