New Power Vision PV2 and Big Sucker on the way...
I'll be installing a PV2 and Arlen Ness Big Sucker intake on my 2012 Softail Lo soon. Does anyone have any advice regarding the PV2 map install or operation of the PV2? It seems pretty straight forward...
I've already got a fatcat installed so this concludes the stage 1 upgrade...
Just follow the directions enclosed with the PV2 and you will be fine. i was a bit confused with old info that i had seen on youtube that said you must save the stock mapping first but, the new instructions will do that for you without your input.
It really does load quick and the mapping that i had received from Fuelmoto was very close as best as i can tell. i have not had time to get it run on a dyno yet but have seen positive results in proformance.
Craig
Craig
