which models rear 200 will fit straight in Blackline
Cutting to the chase I am looking at used 17x6 rim with 200 tire to fit blackline. Can anyone advice which other models wheel will fit easily. I am looking on ebay and coming up with nighttrain, cross bones and other softail model rims which are 17x6 and not sure if there is anything else i need to consider.
thx
thx
Hmmmm i seen someone on youtube claimin he was able to have crossbone rear without ne hussle. Just need more info and options
http://www.youtube.com/watch?v=yts1XRz0sb0
Pardon my ignorance, but what size rim/tire is on the bike now?
If its the same size I guessing that at worst you may need to change the axle bearings to fit yours and different spacers to get the rotor and sprocket lined up properly.
Harley does some crazy things between years, but their not stupid and try to keep costs down by not changing things like swing arms and engine/tranny setups very often.
So its likely that if your bike already has similar sized 200mm tire/rim setup.
Another wheel of the same size should fit without too much trouble.
"The rear fender supports were heated and reformd and the fender cut and widened."
Sounds like you have a fair amount of work ahead of you.
