Ride-On Tire slealant
I am going to switch over to Dyna beads this winter. But I did see that stuff somewhere and thought about using that instead. I ride alot in colder weather and I would be concerned that the stuff would bunch up and throw the balance off??? Warm weather climates would probably be fine. Are you happy with the dyna beads? Thanks
I put Ride-On in my tires last spring. I took the weights off the wheels at the same time. First 1/4 mile was a little rough, but smooth right out. I think it contributed to how comfortable my bike is now. As you said there is the added benefit of a tire sealant. I don't need any more flats!
It goes inside the tube for both of them.
Deflate tire, remove valve core (you need a tool for that)
Ride-On: squeeze the recommended amount in tire trough the valve stem
Dyna Beads: pour the recommended amount using the supplied applicator. (this can be tedious and time consuming)
Replace valve core, inflate tires, go for a ride.
