Had my dealer gap my rings... Grrrr!
#35
you don't even need a ring compressor..you can run push ring in with your thumb,be careful, they are sharp sometimes. or use a hose clamp.. don't use assembly lube on the cylinder. use spray lithium grease.. if you rub oil or assy. lube on, your transferring dirt off your hands on to the cylinder (even if you think they are clean, there is still dirt there that oil releases)
most rings come gaped, but you always need to check them.. all you need is a fine file and a feeler gauge..
#36
Another alternative is the one in the photo, carried at Sears (which also has the KD set). It's under $20, but I have no idea how well it works. You might want to look at these options, if there's a Sears store near you that carries them. Also sold by O'Reilly Auto parts.
#37
This is the style ring compressor you need. the kit i bought has lasted me well over 25 yrs. it has a ratchet lock on the handle end so you can lay the piston down and or move it around and the rings won't turn in the grooves. KD tools sells a similar one that is only around 50 bucks.
I've reused many a piston rings over the yrs. not something i like to do, but if the need arises and you use the right tool to remove them, you shouldn't hurt the rings. i was always more concerned about the seal-ability of the used ring.
#38
what ?????
.that may work for a lawn mower engine you don't really care about, but that is a disaster waiting to happen.. spray lithium grease is for hinges , latches and the like, NOT piston rings.. wow..
my time tested way of assembling the piston was after ring install and preliminary ring placement was to dip the piston assy into a container of auto trans fluid up to and including the wrist pin, then position the rings in the correct position, squeeze the previous shown compressor around the piston and put it in the cyl.. its a little messy, but i have never smoked a ring or cyl on start up or had a engine comeback after repairs. my 67 i put together in 86 still runs today with no problems and has never been apart other then crappy cork valve covers leaking.
i never rubbed any oil or sprayed any type of grease on a piston.
#39
what ?????
my time tested way of assembling the piston was after ring install and preliminary ring placement was to dip the piston assy into a container of auto trans fluid up to and including the wrist pin, ...
#40
I removed the rings this weekend by just walking them off, no ring spreader.
Put them in the cylinder and measured the gaps. It was around .018 and the rings were placed in the proper order.
Used a 3/4 copper coupling and 5/8 spark plug socket to put in the circlips, lubed up the rings and put the piston on the rear rod. cleaned up the cylinder and put some oil in it. Placed it over the bolts and lowered the piston just a bit. Used my fingers and got the rings in pretty easy.
Used 1/2 pvc couplings to temporarily hold it in place while I do the front.
While I was reading instructions etc and taking a break I used some oven cleaner on one of the heads to get a bunch of the carbon build up off. It worked ok, not perfect as if it had been bead blasted but much better then it was.
This weekend was pretty busy so I hope to get more done next weekend.
The gasket kit I got didn't have the cylinder o-ring and the dowel o-ring at the crankcase so I took a trip to harley for those.
Really not a bad job at all!
