Had my dealer gap my rings... Grrrr!
Seriously?
So just putting them in and taking them right back out will cause stress?
Now on a piston that was used in a running engine I could see this but to just put a piston in a bore and take it right back out I find that hard to believe.
Can anyone else confirm this?
That now means my rings are all in need of replacement???
Oh you mean taken off the piston... Hmmmm great.
Now I either have to trust they did the job correctly or risk my rings...
this bites!
this bites!
you should be fine as long as the dealership didn't damage them.
just something i heard about not re-using piston rings. as mentioned, it is probably only applicable to rings that were already run. i've also heard others i trust tell me they've re-used rings with no ill effects.
after all, the same thing happens during gapping the rings - rings are installed in cylinder without piston to measure & correct end gap.
sorry, didn't mean to scare you.
http://www.ebay.com/itm/OEM-27039-PI...item41616f8a7d
You might be surprised how many times you'll use a "one time" tool in a lifetime; I've really gotten my money's worth out of several "will I ever use it again" tools. I'd never re-use rings, either, too much work to replace to not get maximum mileage out of them. Definitely not if it's on new pistons, or a bored cylinder. Just remember to lube the compressor, too, makes it easier.
$150? Where are you looking? 12 bucks for a new one on ebay, including shipping.
I think what the one poster was saying was once they were put onto a piston don't remove them and then put them back on. This could cause undo stress on them.
I could see this especially using a ring spreader to put them on instead of just walking them on the piston.
The pricey one I mention is the HD tool they use. How hard is the one you show to get off in such a tight space like a harley with the cylinder bolts in the way.
This is the style ring compressor you need. the kit i bought has lasted me well over 25 yrs. it has a ratchet lock on the handle end so you can lay the piston down and or move it around and the rings won't turn in the grooves. KD tools sells a similar one that is only around 50 bucks.
I've reused many a piston rings over the yrs. not something i like to do, but if the need arises and you use the right tool to remove them, you shouldn't hurt the rings. i was always more concerned about the seal-ability of the used ring.
