Shamed Into Installing New Nostalgic A/C Cover
RE: Shamed Into Installing New Nostalgic A/C Cover
How about an EVO cover with the insert peeled off? I got this one for about 2 bucks. It bolts right on the the SE Stage I backing plate. Just put a couple of rubber washers between it and the filter element and maybe some stick on 1/4 weather stripping to soak up the vibes and keep the elements center from cracking. I learned this the hard way.
[IMG]local://upfiles/17633/D67EB1C573D34A47A5980E4A5EC206A0.jpg[/IMG]
ORIGINAL: j2dawson
That looks great. I bought one and even with the thick gasket, with the K&N filter, it isn't spaced out far enough. I've been thinking about puting a spacer under the center of the cover.
They now make a plain round chrome one without the logo. It fits fine, but doesn't look near as good as yours.
Jim
Jim
The dimensions for the HD 29442-99D filter used with the 'Stage 1' conversion are; 5 1/2" across at the top, 6 1/2" across at the base (bottom), and 2 1/4" deep...
ORIGINAL: FACTION95
Can you get a chrome screw or allen bolt to replace that stock one?
That way you don't have to worry about it rusting on you.
ORIGINAL: j2dawson
Jim
Jim
