Samson cholo's exhaust clamp
What up Homie's with Samson cholo's, has any one had a problem with the clamps that come with the full systems? I currently had a real loud chirping coming from my exhaust and I took it to a local homies shop. They found out the chirping was coming from the the exhaust where the header pipe connects to the left side of the pipe(crossover I would think). well they put a heavier duty clamp and it worked, the chirping was gone. Now im getting a chirping from where the muffler meets the header on the left side, plus the left side doesn't connect quit like the right side. One more thing, my left side pipe that connects to the bracket is more wiggaly than my right side is, can it be that the left side bracket is more weak than the right? any comment/suggestions would be appreciated, thanks!!
Thank you for your response, I have checked the clamps and they are in the right place. I would not rather put any silicone, is there any other solution besides that? Any other clamps that I could use besides the ones that come with the setup? Thanks
Thanks again for the info, a couple of quick questions then, if I ever needed to change my muffler because of damage ( 39" cholos I currently have) or any other reason with the silicone will it be a pain to remove? Also is there a specific kind of silicone to buy (brand) and can I get it at any auto store or does it have to be a motorcycle shop? Thanks again
Roadwarrior1
Exhaust System Topics
12-02-2012 05:54 PM
