Fatboy Lo wont start!!!
Old 01-22-2012, 02:35 PM
TriggerHappyJack's Avatar
TriggerHappyJack
TriggerHappyJack is offline
Default Fatboy Lo wont start!!!
I have a 2010 Fatboy Lo with 7000 miles. I live in Georgia and have not rode for about a month. When I went out to start her up this morning all I get is a loud rapid "clicking" that sounds like its coming from the starter. I have the battery charging but it is not reading low. I checked the starter relay and its clean. My battery connections and ground connections are good. Does anyone have a suggestion on where to start? I do have a power commander V. I am not that great of a mechanic but I have a service manual. Thanks in advance for any help!!
Old 01-22-2012, 02:36 PM
FLSTF2010's Avatar
FLSTF2010
FLSTF2010 is offline
Click click click. . .when you try to start. My old sporty did that and drove me nuts with a two year old battery. Replaced the battery and she started right up! If you have access to a new battery, replace it and see if that takes care of it.
BTW: I DID have my battery read and it did not read low . .but it was shot!!!!!
Old 01-22-2012, 02:39 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
sounds like the battery voltage is low or a bad connection. ck the ground connections on the frame. charge the battery and try it again
Old 01-22-2012, 02:53 PM
fdb2007's Avatar
fdb2007
fdb2007 is offline
I have charged my neighbor's battery a couple of times. When the book says 12.7 volts is 100% they aren't kidding. I tried the close enough approach and put his back in when it read a little over 12 volts and no joy. It had to be charged all the way. Good luck
Old 01-22-2012, 03:26 PM
TriggerHappyJack
Thanks for the help. I have it charging now so hopefully i can get it running soon!
Old 01-22-2012, 03:35 PM
krwould's Avatar
krwould
krwould is offline
Received 1,313 Likes on 1,028 Posts
You can have a cell go bad in the battery and that will cause it too...
Old 01-22-2012, 03:59 PM
jharanin's Avatar
jharanin
jharanin is offline
+1 on the battery...just went thru that.
Old 01-22-2012, 04:23 PM
tps77's Avatar
tps77
tps77 is offline
I had same prob on 2011 bad cell on battery ,if all connections are good don't waste your time get new battery and check the date the battery was made
Old 01-22-2012, 04:51 PM
RedNose44's Avatar
RedNose44
RedNose44 is offline
Received 7,084 Likes on 2,601 Posts
I also think it is your battery. Unless you test your battery with a load, you won't know if it is good.
Old 01-22-2012, 06:09 PM
TriggerHappyJack
Thanks for the help! I got her charged up and now she is running fine. I will keep a trickle charger hoked up until spring. Is there any way to see if the battery was damaged? I dont want to needlessly buy a new battery but I dont want to get stranded!
Quick Reply: Fatboy Lo wont start!!!
