Relocating Coil on a newer 2011 type bikes?
Kevin,
I'm going to move the coil and remove the seat post and lift the tank. Questions:
1. I'd like Orange wires, Do you Have?
2. Not sure what size tank lift I want, checked your web site for Fatboy pictures with different sizes, NOT.
3. Do you have Discounts???
Thanks for your imputs, Mike
No orange wires. Red & Black are the only colors Screamin' Eagle has for this fitment.
We have looked at a few other cable MFG. for Harley Orange wires...nothing that meets our specs so far.
Sounds like you're waiting on the tank lift. When you do decide you want one the best way to know what size you want it to loosen the rear tank bolt, remove the front tank bolt, use a towel between the tank and the backbone and lift it up to different heights and stand back and take a look...you will see what height you like best, then measure it.
We are running a special right now thru Feb. 12 on the Softail Coil Relo kits...Check it out- Coil Relo Special HERE.
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
Benefit is a cleaner look AND better air flow for the rear cylinder that already runs hotter from being behind the front cylinder. With the coil and the fake seat post out of there, it is amazing how much better air flow it gets.
Softail Coil Relo Pictures
Not to stray too far from the thread...from the 2012 H-D Sreamin Eagle catalog- Orange wires for an 00-Later Softail except FXCW and FXCWC are PN 32360-00B. Not sure if this length meets the requirement but if someone is dead set on Orange, buy two sets and cut the longer ones to fit.
Last edited by mswing1234; 03-07-2012 at 12:06 PM. Reason: Forgot to finish my thought...
Yes, there is room on the ABS bikes, even with the crash bar. The idea that beaselyiv posted is an interesting one also.
