Roland Sands Tracker Seat and Fender
Can anybody who used this set up on a Softail tell me where they relocated the negative battery cable to? At the end of my mods and I'm having a problem getting a good ground...at least that's what I think it is. Remapping the T-Max and after running the cycle doesn't seem like the battery has enough left to get the bike started. Had some smoke from the negative cable thinking its a bad ground. Cranks a few times then clicking....any help would be appreciated.
Thanks for getting back to me on this subject...used the bracket you are referring to but didn't think that I was getting a good ground due to the rubber bushing surrounding the mounting bolt. I came to find out that the battery was just under powered...had enough to run the lights and such but not enough to crank the the motor. Just a heads up to those doing this mod and using a lithium ion battery use no less than an 8 cell and if possible use a 12 cell...
