Cant get rid of the pop
So I have tried everything the forums have recommended. My current tune is pretty damn good but it pops during engine braking and throttle showboating. When I say pop, it is a little gurgling (which is fine) with a deep not very loud pop. Its not bad but its annoying and Id like to get rid of it.
i have tried:
Raising the numbers in "Decel Enleanment" = Made more deep popping
Lowering the numbers in "Decel Enleanment" = Made more deep popping
Maxed out VE numbers in the 0 throttle position between 2000-3500RPM = turned deep popping into loud gun type popping and bad *** fireballs (which was pretty damn cool)
Does anyone have any other suggestions? here is my tune:
i have tried:
That popping has always been there and you won't get rid of it. When you had stock mufflers on you just couldn't hear it. Now that your exhaust is opened up more it is more pronounced. You can change maps all you want but chances are you just have to live with what is a normal condition. But as mentioned above check for a exhaust leak it the popping is really bad or a loud backfire.
I don't know which tuner you are using but: You have ruled out exhaust leaks.
I would bet a penny you are running to lean at 0% throttle. Add fuel at 0% throttle.... then ride it..if it still pops badly...back to the garage and add more fuel..to the 0% throttle ONLY. Don't mess with the other cells. Add more than you think you need..then ride it..if the popping goes away..and the bike only gurgles..then go back to the garage and take fuel away, from 0% throttle ONLY..a little at a time..then ride it..if still no popping,,take a little more fuel away. Do this until popping returns..then add the last bit you took away....now only gurgles. It worked on my bike,,,running PCIII with Dyno Tune...
uh, how does that work? cutting 100% of the fuel, at zero throttle sounds to me like the engine dies everyt ime you close the throttle. does that work good for you at redlights? lol. maybe i am missing something?
I suspect it is a terminology difference. I agree if you remove all fuel it should die, however that is what the setting is in the T-Max software. I suspect it is fuel above idle flow. I did read that after I posted it and said to myself "how does that really work" and actually went out to the garage and loaded the software to make sure I was not off base, but yup, that's what it says. I also remembered that I did add a bit of timing at zero throttle too. Not sure now if that was for popping but it is there. Too long ago to remember all of this stuff, I'd rather just ride.
