I have everything removed but the fuel line, just wanted to know if there some special steps that I need to take to remove the fuel line. Any help would be appreciated.
Remove the fuel pump fuse, crank the engine over to relieve system pressure, it may run for a second but that's about it. You can then remove the fuel line without damaging the o-ring in the fuel line.
