Wrinkle paint to Night Train detachable Sissy bar mounts
Sons 09 Sissy bar came in W Bk.
heres the links for Ur 06 in bk..
sissy bar
http://www.harley-davidson.com/gma/g...bmLocale=en_US
detachable side plates.
U and ur parts guy sure didn't look very hard
sissy bar
There is a signal relo kit, don't remember the part number, but the dealer will have it. IIRC, and its been awhile since I ran the stock rear sigs, but it just moves them rearward about an inch. There is either an existing hole there, or one needs to be drilled.
EDIT: It was p/n 53933-03 for mine. Found it in the old paperwork.
Thanks,
Tony
The biggest problem I had was that I installed my docking bolts with blue loctite. The bolts apparently come with yellow loctite and when you add blue to it, it basically locks them down and the only way to get them off is heating them up with a torch. Of course HD doesnt tell you to take the yellow loctite off before putting the blue loctite on. :/ You have to clean them before reinstalling them. I don't have a torch so I finally had to take mine to a dealer. I let them deal with it and installing the turn location kit...cost me $230.
I cut the sissy bar docking plates to allow room for the signals, then touched it up with black nail polish.
RIP- I used liquid sandpaper or denatured alcohol just to take any oil or grease off of them.
Tony- I did the same as RIP and cut the mounting plates on the sissy bar with a Dremel instead of moving the lights.
There are several threads on this that can help you. It's easy to do.
https://www.hdforums.com/forum/softa...failure-3.html
