balance beads??
great,have to add them to my list for you when i order my wheels/tires soon,,can i get a package deal drew,air ride,rims,tires,rotors etc. mounted and balanced?
I can't believe this thread is 6 posts long without someone pointing out how many threads have addressed opinions and observations about these magical little beads. Zoom Splatt riders have been using them for years.
They work well, tube or tubeless. Takes no special skills to install. Engraver or even an electric toothbrush expedites installation in the valve stem on tubeless tires. Just dump them in a tubeless tire while mounting. Use safety valve cores so the air doesn't leak out if a bead gets in the stem when checking air pressure. Etc, Etc.....
Search the internet for balance bead problems and you will find that there are mixed reviews. I think that since motorcycle tires do not last that long, any of the claimed problems with beads are not an issue.
If you are DIY, then they probably will help.
If you do the tires in a shop, I think it is six of one a half dozen of the other.
An out of round wheel, otoh, might not respond well to them so over time they could become destructive on improperly maintained laced wheels by trying to make a wheel balanced that cannot be balanced and thus over working the suspension when compared to not having them at all (the wheel would basketball more, not less).
One question that makes sense... why wouldn't they come stock on your bike if they are so good?
C#
C#
