88ci Twin Cam in a 1999 Fatboy?
I purchased a 1999 fatboy a couple weeks ago. As most of you probably know, 1999 was the last year of the 80ci EVO motor in the Softails. Today I went to change the spark plugs so I went to the dealer and asked for plugs for a 99 Fatboy. I took them home, pulled the old ones out only to discover they were the wrong plugs. I pulled out my parts catalog and found that they were in fact the correct spark plugs for a 99 fatboy... but not my 99 fatboy! Confused, I went back to the dealer and explained the situation and showed him the spark plug I took out. He looked up the numbers and said it was the plug used in the 88ci Twin Cams. He said what most likely happened was that my bike was put together toward the end of the year when the transition from the EVO to the Twin Cam was taking place and I ended up with a Twin Cam motor in my 99 Fatboy.
Has anyone ever come across this... or similar happenings??? How do I know for sure that is what the case is and that my motor is in fact a Twin Cam?
I never thought of that... heres a pic! I can tell tho by looking at the pics you posted that it is in fact an EVO tho. I dont understand the plugs being different then. Its not that someone put the wrong plug in, the threads are 2 different sizes. It does have Screamin Eagle heads installed on it... could that be why the different plugs? Youll have to excuse my ignorance, Im kind of a newbie and not real knowledgeable about motors!
Here's a link to the Evo forum: https://www.hdforums.com/forum/evo-classic-models-84/
