Wheel Differences
Old 12-07-2011, 04:58 PM
bpope's Avatar
bpope
bpope is offline
I would really like to see one in person. I kind of like the 40 spoke look...just seems like it keeps it looking pretty nostalgic. Motown...your bike is bada$$. I have the same pipes on mine.
Old 12-07-2011, 05:20 PM
BrianG's Avatar
BrianG
BrianG is offline
The OD of the bearings is the same (52mm) so it is just a matter of the bearing ID. The trouble is that finding a metric OD and SAE ID isn't easy outside of buying the HD ones from a dealer.
The other issue is the bearing spacing in the wheel and the 2 different widths of the bearings. One is 15mm the other is 18mm. This is not hte case with the 3/4" ID bearings which are both 15mm wide.
Trouble also arises from the fact that the bearing housings are also different. One bearing housing is 19mm deep while the other is 26mm deep.
For my installation of a 17" profile, laced Touring wheel (dual disc) on my 2004 Softail, I will simply set the bearings to the depth that gives me the same outside spacing as the 16" 2004 wheel had.
As well, bearings should be set against a facing in the housing. It appears that this will not occur with a pair of 15mm wide bearings. This will mean building 52mm spacers of the correct width to locate the bearings in the housings, and building the internal spacer to match the resulting inside bearing interspace.
Then one will have to be certain that the external spacer(s) locate the brake rotors correctly in the calipers.
Old 12-07-2011, 05:27 PM
bpope's Avatar
bpope
bpope is offline
Good info Brian...thank you!
Krazykay5487
Softail Parts
03-31-2015 07:52 PM
MidnightRider112
12-30-2014 03:02 PM
Alphadiver
06-06-2014 10:15 PM
machm1969
01-18-2014 09:23 AM
mike lhc
11-23-2008 04:41 PM
Quick Reply: Wheel Differences
