Belt slippage.... Normal?
I'm no motorcycle mechanic, and it seems that the belt would slip before i sheer metal splines. I just cant imagine a stock 96" can sheer parts by just dumping a clutch.
Yeah im guessn has been checked during my last service, had a tire put on by an Indy and thinking they maybe left it a little slack. But its not like the oil patch or clutch slipping that last for couple seconds, its just one "clunk-ish" sound when clutch is dumped
Dont take this wrong, but is that a fact?
To check the belts tension, just twist it by hand. Proper tension should only allow about a 45 degree twist. If you're jumping teeth, your belt will probably twist 90 degrees or more. It's that simple to check.
Last spring after getting mine back from an Indy shop I had the same thing happen where I did jump a few teeth on an aggressive launch. I just adjusted the belt tension at the rear axle adjusters and end of story. I'm still using the same belt 6k miles later and there was no visual damage. Of course mine only jumped teeth once. I'm not sure how many times you can do so without damage, but I'm sure it's not many.
Now go check that belt tension and be done with it!
Good luck!
Well went by the dealer and talked with one of the service guys there that has always been straight with me.... belt was "Way to loose" we looked it over and belt is still in good shape. They gonna tighten it up for me while they got it doing some other odds and ends. So hoping Wed when i'm back in town, everything should be good to go.
But thanks guys for all the good info.... be safe, Rubber side down!
