Power Vision
Power Vision
Been looking at tuners and have decided on a DynoJet Power Vision tuner. I have slip on pipes as of right now. Was going to add a new a/c and try one of the pre configured maps to see how it would improve performance. If I were to change my cams later down the road would I need to have the bike dyno tuned or would the PV be able to compensate? Any other info on this unit and what to expect would be greatly appreciated!!
By reading his statement I don't think that is what the OP meant and regarding it voiding your warranty it really is a non issue.
Yes, you can do that... but they don't have every possible combination of parts.. so you're not limited by just what you can download... That's where FuelMoto and others step in... You also have the capability of modifying your own maps with the software.
What are ya gonna do about your aftermarket pipes and air cleaner that are still on the bike when you take it in for servicing? If the OEM ECM (Electronic Control Module) isn't tuned with a download from Harley for those add-ons it will make the engine run really, really lean! That will cause damage, and the Dealer will make notes in his computer about your bike's current setup and say it's your fault if any damage occurs in the future.
I was told by the manufacturer that they could also do this.
I bought my unit from Dennis Kirk for $440.85, which I believe was
cheaper than FM.
https://www.denniskirk.com/dynojet/p...rd/2000458.sku
