frenched turn signals
Old 11-24-2011 | 08:28 AM
JohnFlorida's Avatar
JohnFlorida
Default frenched turn signals
Put on frenched headlight and spot rings with no problem but can't get the turn signals to fit. Looks like the lenses are too big leaving about a 3/8 gap on the ring. Only solution I can see is to grind the lenses just a bit. Any ideas? I know this is pretty common so someone must have got it to work. Using J & P rings
Old 11-24-2011 | 08:46 AM
seph10's Avatar
seph10
I know on my ultra I had to loosen up the lens a little so the lip on the back of the rim would fit behind the lens enough to make it work,,,and there may be a small notch that has to be lined up also,,,
Old 11-24-2011 | 11:09 AM
JohnFlorida
Loosened lens but no notch. Lens is a larger diameter than the ring
Old 11-24-2011 | 12:58 PM
Daddy-O's Avatar
Daddy-O
Product reviews on JP's website show others had the same problem.
"They look great when installed except for the gap at the bottom. A little thinner foam would probably allow them to close completely. I had to trim about a quarter inch off of the foam to even get them on. Good quality and finish."
"Had to remove the foam and install thinner foam to get them to fasten. Still a 1/4" gap after the install. Looks pretty good though."
Seems like trimming the foam or replacing it with thinner foam may help. The HD rings come with an o-ring spacer that allows the trim ring edge to catch behind the lense and the ring to sit closer.
Old 11-24-2011 | 05:36 PM
JohnFlorida
Mine came with an O ring too but no foam . No foam to trim all I can trim is the plastic lens
Old 11-25-2011 | 03:25 AM
Daddy-O's Avatar
Daddy-O
Sorry, I think I may have been looking at the passing lamp rings. Sounds like they go on the same as HDs. Are you able to get the back edge of the ring to drop in around the o-ring? I do remember something about aligning notches but it was a while ago when I put them on. If I get time I'll take a closer look at mine tomorrow.
Old 11-25-2011 | 07:36 AM
JohnFlorida
I can get em on but no notches and a big gap. I got a couple extra lenses laying around so I'll try grinding them today
KYBill
04-25-2017 04:19 PM
ShockwaveTXB
07-01-2013 10:19 PM
Butts05Train
02-15-2013 05:43 PM
timvan
03-19-2009 07:37 PM
jsbridgew
11-13-2007 10:52 AM
