Automatic Fuel Controller
Claims to use the stock ECU and stock O2 sensors
• The only "closed loop" fuel management system that utilizes the factory Delphi ECU and factory sensors• It'll give an increase in horsepower and torque up to 20% while working in conjunction with both factory and race tuner downloads
• It maximizes performance and efficiency while decreasing emissions and fuel consumption
• Uses both factory O2 sensor
It is my understanding that in order to actually get the most out of a closed loop system you must use Broad Band or Broad Range O2 sensors (stock are narrow range). Looks like they took a short cut and turned the use of stock sensors into a selling feature. I would let someone be the guinea pig.
There is more than one model. The one in the link below comes with a O2 sensor. One of you more knowledgeable guys ought to call them to get the straight poop.
http://www.motorcycle-superstore.com...45&zmap=265296
In fact they have a ton of different models:
http://www.terrycomp.com/Products.aspx
Sorry for delay, had to search for the link, it's in the 2012 model year Technical dealer presentation.
here is the link where you can download it:
http://www.box.net/shared/d2g4qk9d1nrphoz3h6i1
It's on page 13 for softail models and gets mentioned on couple more pages.
They change from 2-wire O2 sensors to 4-wire heated O2 sensors. Might be they are still narrow band ...
