Can't get Air Filter off.....help!
Hope everyone is doing well. I'm new to this sight so please bare with me.
I bought an 06' Deluxe flstni about 7 months ago. I decided to take a look at the air filter. Well, it was dirty so I decided to replace it.
I took off the chrome cover with the center bolt. When I went to remove the three screws that secure the filter I broke two torques bits.
I could not get the screws loose.
Please keep in mind that I use to be a car mechanic but bikes are new to me. What the h*ll can it be? How do I remove these bolts?
Any help would be greatly appreciated.
Sounds like maybe U need to get some good tools.
My dad give me some torx sockets that broke very easy, their in the trash yard now.
I use almost nothing except Craftsman, If they brake they'll replace it. In 38 yrs of being a machine repairman at work I had only 1 Craftsman tool brake. It was a 1/2 " ratchet wrench and it failed because I had a two ft piece of pipe on it to get more leverage. Even then the Wrench didn't brake, the gears inside it did.
Also most mechanics that knows very much knows U can also use a small chisel to tap a bolt out if its head is stripped. so U could try old trick that too. Tap the chisel parallel to the bolt head at a 45* angle to the CL of the bolt on the outside dia. of the head.
If loctite has been used U may also try heat to the bolts.
Just though of an other tool I have, an Strike blow hammer impact wrench . it will remove a lot of stuck bolts too.
Ran into the same thing with my X'Bones. Some CS at the dealer WAY over torqued the three bolts. I'm a mechanic by trade also, and broke my Snap On torx trying to get it off. Got a Matco one, some valve grind compound for extra grip, and finally got the stupid things out. Hate to think of having to drill them out and using an easy out. Never anything easy about that. Good luck.
Thanks for the help!!!
Well, I went ahead and did as FroggyFatBoy suggested.
I ran the bike for a bit and let it heat up the bolts. Believe it not, they couldn't have came off any easier. They did seem to have some type of locktite or something on them. As soft 02 stated, the heat seemed to break the locktite compound.
Just for the record, I too use Craftsman tools. I also had a couple of torx bits from my old job, as I use to work in the auto manufacturing industry.
I also used the correct size (T-27) bits.
I really appreciate all of your suggestions and help.
