hello all, ok the vance & hines pipes are on the bike, now i would like to change the air cleaner to a screaming eagle heavy breather and i will also need a tuner which tuner ?? were is the best place to buy thse items ??
Start reading bro. There are a million posts on here about that stuff. Most think fuel pal if all you are doing is the pipes and stage 1 a/c.
As for price- shop the web! Lots of deals to be found. I've had good luck here on the classifieds.
Good luck!
I personally would tell you Sert or TTS Mastertune if you care about the performance upgrade with dyno'd. If all you want it for is looks and sound, then vance and hines fuel pack.
