Duals with passenger boards.
10-10-2011, 07:35 PM
Anyone have duals with passenger floorboards? They say it won't fit but it looks like they would fit
Pictures?
10-10-2011, 09:33 PM
I have dual exhaust and run the floor boards and do not have any problem fitting.
10-11-2011, 09:13 AM
This has been discussed in several threads, right down to the part numbers. The Deluxe uses the stock exhaust bracket to mount the passenger floorboards. Since you remove the stock exhaust bracket to install the duals, the floorboard can't be mounted. The work around is to get the heritage mounting brackets. If you search you can get the part numbers.
10-11-2011, 10:55 AM
My only concern is the left side. Has nothing to do with deluxe pipes, it's if the left pipe will fit with boards
Fire what pipes do you have
10-11-2011, 05:00 PM
Mine are HD passenger floorboards mounted on Kuryakyn anti-rotation mounts. The lighting isn't very good, but here's a few pics..
10-11-2011, 05:49 PM
So they will fit? Samson told me I might need a spacer to kick the floorboard out, not the case? Any issues with the lady burning pants/ leg/ boot
10-11-2011, 06:28 PM
Quote:
Originally Posted by
kozy22
Left side no problem, your issue will be on the right. This only pertains to HD floorboards.
10-11-2011, 06:30 PM
10-11-2011, 06:37 PM
I didn't use any spacers, there is enough clearance. The mounts are stationary but the floorboards themselves can be rotated (tilted) up or down on its axis. This allows choice of foot placement. Your toe area is closest to the heat shield, no leg or boot burns. I'm very pleased with these mounts. I may have a rear end pic with the fb's extended out. I'll see if I can find it.
10-11-2011, 07:01 PM
I couldn't find any of the left side but here's one of the right side.
Derek Paradise
06-09-2019 09:07 AM
MatthewJay
08-02-2017 01:53 PM
911and996
04-06-2017 11:39 PM
KeeBee
03-07-2011 07:21 PM
BugSlayer
11-27-2006 05:35 AM
