?'s for those who have wrapped their pipes
Kicking around putting some big radius 2 into 2 on my Rocker.
Is there a big difference between models of heat wraps?
I've seen where certain brand models recommend re-jetting carb would an EFI model need to be dyno'ed after changing just the pipes and adding a heat wrap?
Would there be any issues with wrapping just where the rear heat shield is and keeping the chrome heat shield on the front section of the pipes?
Higher end wrap like thermo tec and DEI are worth it. I have cheaper stuff on my current pipes and it shows. I have used all brands.
If your bike is running fine now you don't need to do any tuning after wrapping.
And to answer your last question no. Don't worry about only wrapping part of the pipe. That is what most do anyway.
Wasting Time, Yep just like adding Chrome or painting some part a different color or ? Most manufacters will tell you not to wrap cause it will trap moisture and rust or crack pipes. I've wrapped my stock pipes (used the dry wrap method, no paint yet) about 5000 miles ago (pipes been wet a few times) with Lava wrap. So far no problems, Planning on installing D&D Bobcats someday anyway. Will probabley wrap them also, just for looks mostly, couldn't really tell difference in heat.
With the rusting pipes topic open.
I have noticed different ways of applying wraps via youtube, one painted pipe with a flame proof paint prior to wrapping and then adding a silicon sealant over the wraps and others just wrapping pipes.
Also a video showing the pipes after a being used and wrapped for over 18 months. It showed some surface rust, but nothing too bad. He didn't use the silicon sealant.
Any facts on whether one application process vs. the other is better at preventing rust or ways to eliminate it all together?
just wrapped my exhaust last night... chrome was gettin thin on my hooker troublemakers, I painted em with the high heat paint first, got the wrap wet, and went to town last night. tied one end to the shop door so I could pull it super tight... gonna go out and paint em today once the wrap dries out
