Tank lift fuel range and cams vs. big bore Q's.
I put a 3" tank lift on the Deuce. Stock it's got 4.9 gallons it's supposed to be able to use. Right now, after my first fill up after the lift, I have about 95 miles on it and the needle is sitting firmly at the 1/4 of the red bar mark and it's been telling me to fill up since 60 miles. Am I OK to push 150 miles on a tank? Any wisdom on this matter will be appreciated.
Also, I'm saving for some engine work this winter and I'm wondering what'll give me the most bang for the buck on an 88ci EFI motor, cams or a big bore kit? 3K rpm is my sweet spot. That's where I'm about at when cruising and that normally where I start when I roll on the throttle for turns and hard accelleration. I read that the 88B redline is 5.2K and cams I've looked at have the powerband placed way above that for some. Will the cams allow you to run the engin at a higher RPM? I'm confused on that subject, but I think a cam that can put the powerband squarely between 2.8k and 5.2k RPM would be a keeper for me.
Any suggestions on what to look for if I do cams over the big bore?
Hey Bro. I am in the process of putting on a 3 inch lift on my rocker. What I was told is that you will still get the same range of mileage that you got prior to the lift. My fuel injection hose it out of the end of the tank nearest the seat anyway, so the gas is running back there with the tilt. Anyway...if 150 was the average you got previously, then you are gtg. I think that was my average too.
When I get all of my mods done and the bike put back together, I guess we'll see...lol. I may stick close to home once I hit 130 on the first tank to see what the real deal endpoint is.
I chose cams and headwork over the big bore. Had the heads decked and cleaned up, installed Crane 310-2 cams (don't think they make them anymore), and adjustable pushrods. Ended up with 82hp and 94tq. Not sure of the stock redline, but mine is at about 6200 RPM. I attached a copy of my last Dyno.
Some of the cost was covered under warranty (bad valve seals) but something like this would probably run in $1200-$1600 range depending on your local hourly rate and cost of parts. Good luck!
Any idea where I can find a service diagram of the tank without purcahsing a whole service manual?
Edit: Sweet, I see you're in Frederick. I bought my bike from Williamsport HD.
Frederick does have a great machine/custom/collision shop that is completely separate from the service dept. It's part of their HDFR racing team and it's in the building on the corner of Grove Rd there. Had them do all the machining for my fat front tire conversion and was very pleased. Good bunch of guys, and none of the "that's not a HD recommended upgrade" BS. Cheers!
John.
However, if you pass on the 95" upgrade for now, there are several cams that will work well in an 88" motor but you really should invest in a $299 BigBoyz "street" port job, or at least have your stock heads worked over by decking them to set the compression for whatever cams you select, a triple angle valve job and new guide seals. Cams that you might look at are Andrews 26 and 37; Woods 6; S&S510 and SE204. These are similar in profile to the Crane cams jreichart is running.
You need fuel management; the upgraded motor will have to be tuned. Many options; talk to your local tuner.
BTW, 5800rpm is the rev limit for the 88B motor. The rev limit is controlled by the ECM; engine modifications have no effect. The rev limit can be increased via the fuel managment system you choose; max I would run is about 6200rpm.
