Widest rear tire width on stock Blackline rim
Just picked up a new 2011 Blackline and I absolutely love this thing! Handles like a freakin' champ and is quite comfortable. The look is exactly what I was looking for except the rear tire.
Is it possible to put a slightly wider tire on the stock rim? Not looking for a 200 or anything like that, just a little bit more width. Also, I would like a tire that doesn't have quite as high of a sidewall to give the rear a little lower profile look.
Any suggestions would be greatly appreciated!
Thanks for the reply!
I think it looks so narrow to me because I'm coming off a Rocker C. Tonight when I went down and gawked at my new pride and joy it didn't seem as narrow as yesterday. I guess it just might take some getting used to.
I will say the bike corners and handles very well with that narrow tire whereas the Rocker seemed to wallow in the corners and never utilize the outer edges of the tire causing it to get a flat spot.
Is your Blackline lowered in your signature pic? It looks a bit lower than mine. Also, I noticed you relocated your plate. Did you go with a axle or swingarm side mount?
Thanks again for your time.
I haven't done anything to my suspension yet, it is still stock.
This is Cycle Visions, mounted on the axle. Gives plenty of room for the swingarm bag.
Don't know how much room to spare U got, our heritage uses a Lop 401 rear in size 150-80-16, Its about 1/2 wider the U stock tire. So far on the 4 I had on they all get right at 10k riding two up 95% of the time. mostly just putting on the county roads.
heres the specs.
http://www.dunlopmotorcycle.com/tire..._tire.asp?id=6
heres the specs.
It's all gonna depend in the brand. Supposedly the stock tire is a 144. That is supposed to mean it is 144mm wide. If that were truely the case, and you went to a true 160mm wide tire, you are talking 16mm which is very close to 5/8". That should be doable.
The problem is that different manufacturers build their tires different sizes. Then the width of the rim will have a small effect on the treadwidth when mounted as well. Best bet is try to find someone local running that size tire, and take a few measurements.
I would love to go a hair wider tire on mine as well, but I want an 18" rear wheel to go with it, so I have held off for now.
