Thoughts on Grip Ace and Exile Cycles internal throttle after a few hundred miles
Drew sorry for all the questions.But do you know if Carlini makes bars that are not dimpled for wiring? If so would this eliminate the welding part? I was thinking of changing to 1 1/2 " Flying Apes instead of my current 1 1/4 Gangster's.For more pullback and the thicker look.If so that would be one less thing to worry about.Or do you still recommend welding them?Everything would probably make more sense if I had the parts to look at in person.
Another question? Part of the reason I never bought the 1 1/2 " Carlini is because they seem very wide to me at 41.5 " end to end.Instead of making the spacers for the bars could you just cut the bars on both sides.So the grips would be next to the mirror clamp on one side and the master cylinder clamp on the other side.Eliminating the spacers all together.And bringing the overall length of the bars down (end to end).What are those spacers about 2" long on each side? Would that work or is it even possible?
Questions are good. I don't think they make non dimpled bars but am not sure. Call them and ask. I would recommend welding it regardless to be sure it stays in place.
As far as the spacers go, once I get mine all done with everything I am sure I could get you the dimensions or hook you up with my buddy who made them and have him use mine as a template. I'd say the spacers are about 1.5" or so.
I Just measured the bars. 39.5" wide now so they are 2" narrower. I guess you could make them a bit narrower as long as the internal throttle is welded in. You might have to drill a hole for the throttle cable and Grip Ace wiring, but It could be done. It will just take a little time and measuring to figure it out. If I had not planned on using the set screws isntead of welding I could have made them narrower now that I think about it.
Remember you will need new risers as well if you get the 1.5" bars. You should do this mod. Not as big a deal as it seems. Time and patience will pay off big time for you. Your bike is already so nice that this will be the icing on the cake.
Drew
Drew
Drew
Drew
Thanks Rob.Your bars have been renting space in my head ever since I saw them.Now I see Drew's bars and it is just a SUPER CLEAN look.I don't see how I cant give it a shot.Time ,I will have plenty of that soon no doubt.Its the skill and patience I'm worried about lol.After seeing your speaker mounts,bars and the custom bars you made for your buddy's V Rod.It is obvious that you are a very talented and skilled in working with metal.Me not so much.I have a feeling you and Drew will be getting lots of PM's If I decide to take this project on.
@Malingerer, yes, there is a simpler but more expensive way to do this and it is getting Cyril Huze apes which come with everything pre-wired internally (clutch, brake lines, electrical and throttle/idle) those are plug and play but you have to convert your clutch from mechanical to hydraulic, easy to do, there are several systems in the market.
The Huze's setup is beautiful the switches are concealed and you only see flawless smoth lines from grip to grip.
Check 'em out:
http://store.cyrilhuze.com/CyrilHuze...roductID=10225
http://store.cyrilhuze.com/CyrilHuze...roductID=10231
Mimo.
They do take orders for custom handlebars, yo can get them anyway you want.
Check 'em out:
Mimo.
Check 'em out:
Mimo.
Thanks for the info Mimo. I had no idea. Just got back from 800 miles in the last few days. the throttle and grip ace work perfect. No issues, no problems, just riding.
Drew
