When to change wheel bearings
Old 09-23-2011 | 08:52 AM
gvallanc's Avatar
gvallanc
Default When to change wheel bearings
Just had new tires put on my 05 Heritage Softail. Had 21,850 miles on them. After installing tires the dealer suggested I change the wheel bearings in the near future, but did not say they was anything wrong with them. Should I be concerned?
Thanks in advance for the input.
Old 09-23-2011 | 10:27 AM
poppavein's Avatar
poppavein
Wheel bearings are typically checked when replacing tires, and replaced then if needed.
He is only going by mileage; if he had felt any roughness in the bearings, then he would have recommended replacement at that time. I don't replace mine based just on mileage.
You might not want to wait another 20k miles before checking. You can do it yourself; remove the wheel and then rotate the bearing with your fingers. If it isn't totally smooth then have it replaced.
Old 09-23-2011 | 10:52 AM
jreichart's Avatar
jreichart
I have 43k on my wheel bearings, never been changed as far as I know. Might have em swapped out this winter when I've got it all apart, but they seem to be fine so far.
Old 09-23-2011 | 05:40 PM
olongapo1's Avatar
olongapo1
Wheel bearings are relatively cheap and an easy replacement. They should be checked every tire change and replaced if there is any suspicion of degradation. A buddy of mine wrecked his Road King when a front wheel bearing failed.
Old 09-23-2011 | 05:43 PM
prost34's Avatar
prost34
did not know my left bearing was shot with only 11000 miles,until i laid the bike down,,bought it with 10k
Old 09-23-2011 | 05:45 PM
soft 02's Avatar
soft 02
07 FXST wheel bearings $11.00 and mine go bad about every 25,000 miles but I'm still on the original rears.
Old 09-23-2011 | 05:49 PM
Stiggy's Avatar
Stiggy
Check mine every tire change, and my originals are still in there at 94,000 miles. I've got a set of bearings to install on the next tire change (at about 100K.)
The newer bikes, (2008 and up,) with the 25 mm axle only have single row ball bearings in them and are apparently more prone to fail WAY earlier than that however.
Old 09-23-2011 | 06:53 PM
Recon Dad's Avatar
Recon Dad
You got 21,850 on original tires? I can't get more than 5,000 to 6,000 on the rear tire.
Do a lot of two up riding and long trips.
Brian MD.
09-13-2016 10:39 AM
jmn1960
01-22-2014 01:47 PM
Dirty Bob
09-17-2013 09:56 PM
cameraboy
09-10-2011 12:55 AM
Professor
08-16-2008 06:48 PM
Quick Reply: When to change wheel bearings
