Whats the one best power upgrade?
This is the Cam I was thinking...
NOTE: 99-06 Twin Cam motors (except 06 Dyna Glide) cannot use the 2007 cams, as the bearing journal on the earlier motors is .875 in. in diameter and the 2007 cams are 1.000 in. in diameter. The "N" series of cams feature the .875 in. bearing journal, yet still accept the new style cam support plate.
NOTE: 99-01 model motors must use the Andrews rear cam sprocket - PART #140050. 2002-2006 models must use the stock rear cam sprocket, OEM # 25728-06.
NOTE: Installer must check coil bind, valve-to-valve clearance and valve-to-piston clearance.
FOR 99-06 TWIN CAM (EXCEPT 06 DYNA GLIDE)
37N GRIND CAMS
Specs:
Intake:
Open: 18 degrees
Close: 38 degrees
Duration @ .053: 236 degrees
Duration @.020: 272 degrees
Valve Lift: .510
Lift TDC: .174
Exhaust:
Open: 46 degrees
Close: 14 degrees
Duration @ .053: 240 degrees
Duration @ .020: 276 degrees
Valve Lift: .510
Lift TDC: .148
- Allows you to upgrade your 99-06 Twin Cam (except 06 Dyna Glide) to the newer roller-style cam chains and replaces the spring tension cam chain adjusters with the later-style hydraulic adjusters for longer life
- Cam grinds listed are designed to be used with stock lifters
- They require the installation of a 2007 cam plate, oil pump, cam sprockets and chains, and both hydraulic chain adjusters
- These parts are not included and must be purchased separately
- A list of required components is supplied with each set of cams
- Performance should be similar to earlier bikes with the same cam grinds.
37N GRIND CAMS
- Bolt-in cams for 88 in. or 95 in. motors
- Smooth idle, broad torque band
- Run best with low-restriction exhausts (2200-5800 rpm)
- Can be used with stock valve springs and tappets
Specs:
Intake:
Open: 18 degrees
Close: 38 degrees
Valve Lift: .510
Lift TDC: .174
Exhaust:
Open: 46 degrees
Close: 14 degrees
Valve Lift: .510
Lift TDC: .148
