Has Anyone had problems with the Kill Switch?
Old 09-17-2011 | 10:15 AM
Whir's Avatar
Whir
Default Has Anyone had problems with the Kill Switch?
I'm riding down the road the other day and suddenly everything gets quiet.
I look around a bit nothing unusual except the lack of engine noise.
Pull in the clutch thumb the starter and get a quick fire then nothing.
So I get pulled over put the bike into neutral hit the starter and nothing.
Going through the K.I.S.S. checklist I hit the kill switch to off then back to run and it fires up like nothing ever happened.
So my question is has anyone else had problems like this?
I normally just use the ignition to shut the bike off so I very seldom even touch that switch.
Old 09-17-2011 | 10:38 AM
sandman2004's Avatar
sandman2004
I did. I sprayed the switch with some electronic cleaner, turned the switch on and off several times. All is well I never use the kill switch just the ignition switch.
Old 09-17-2011 | 11:00 AM
ChromeJunkie's Avatar
ChromeJunkie
It's never happened to me, but I have heard of it happening to several people. Try doing the electrical cleaner thing like Sandman said. I won't hurt to try.
Old 09-17-2011 | 11:13 AM
cwsharp's Avatar
cwsharp
It happened to me once. I took mine apart, sprayed it with electronic cleaner, then stuffed it with electric grease (dilectric). So far so good, but I'm sure it started out clean from the factory stuffed with electric grease.
C#
Old 09-17-2011 | 10:35 PM
Whir's Avatar
Whir
Thanks,
That's along the lines of what I was thinking
Old 09-17-2011 | 11:01 PM
nikonf8's Avatar
nikonf8
Default switch
my kill switch broke and you cant just buy the one you have to buy the whole set its not that expensive i think it was eighteen dollars
Old 09-24-2011 | 02:29 PM
sweet07's Avatar
sweet07
I came across this thread on my search for kill switch versus ignition switch. I remember reading on here that using the ignition switch only, puts ur charging system at risk. I ignored that and kept using IS only. Guess what? My regulator took a dump. Having it and the stator replaced. Ain't cheap.
Old 09-24-2011 | 02:49 PM
cwsharp's Avatar
cwsharp
Hmmm... never heard that one and I don't know anyone that uses the kill switch instead of or in addition to the ignition switch. I would have to look at a wiring diagram to see which wires were affected by each... but I would say that you use the kill switch to kill the engine but you could still activate your hazard lights, etc. Dunno... never thought about it.
C#
Old 09-25-2011 | 06:37 AM
FroggyFatBoy's Avatar
FroggyFatBoy
i always use the kill switch to shut'r down. switches have a funny way of corroding/oxidizing if not used. by using the switch it actually keeps itself clean by the sliding of the contacts across one another.
Fillykonk
05-01-2022 03:46 PM
Petiej
Electrical/Lighting/Alarm
08-21-2019 07:12 AM
Guitardude
07-05-2016 09:20 AM
specialidiot
07-23-2014 09:38 AM
HarleyDrifter
08-26-2013 09:46 AM
