Handlebar Options for Night Train
Old 11-20-2006, 07:21 PM
Sidehack's Avatar
Sidehack
Sidehack is offline
Default Handlebar Options for Night Train
I'm interested on what bars with more pullback can be installed on the NT without cable/hose/wiring changes. Mine currently has Deuce bars and risers but the grips are still too "straight out" for my comfort. I'm interested in conversions that maximize the extent of the original cables.
The moco #56029-00 conversion kit appears to be no more than 4 1/2" bent risers with a certain Sporty bar; anyone using this setup? Pictures?
(Update, I chose bars from a Softail Standard)
Old 11-22-2006, 09:46 AM
Pops28's Avatar
Pops28
Pops28 is offline
Default RE: Handlebar Options for Night Train
HD has a kit specifically for the NT. It's a pull back with new bars and brings them back 5" with a slight bend and uses the OE cables. Check the catalog, or web site, I don't have the part number in front of me, but they're only about $150 .
The problem with changing bars on a NT is always going to be the cables. Since the drag bars are so short, the OE cables are about the shortest of any in the Softail line...
Old 11-22-2006, 09:58 AM
DI75's Avatar
DI75
DI75 is offline
Carlini drag bars,internal wiring,awesome custom look. various pullbacks depending on your needs!!
Old 11-22-2006, 11:16 AM
Soul_Cal's Avatar
Soul_Cal
Soul_Cal is offline
ORIGINAL: Sidehack
I had the black sporty bar and didn't like them becuase they were too narrow. I quickly took them off and put some Arlen Ness 1 1/4" Flat Track bars with Built-In risers. They were internally wired with the original cables. You won't have a drag bar look but they are very comfortable -- definitely more pullback than stock NT bars.
Another option would be to get some 4 1/2" bent risers with the stock drag bars. The bent risers will make a big difference. I've sat on a bike with this set-up and it was very comfortable. Good luck!
Old 11-22-2006, 11:18 AM
jbt's Avatar
jbt
jbt is offline
I put XL1200 bars on mine, on Deuce risers. Less reach, great comfort, clears the tank, and all stock wiring/cables. I'd post a pic, but don't have a good one of the bars.
Old 11-22-2006, 12:12 PM
PhatTrain's Avatar
PhatTrain
PhatTrain is offline
Originally I had 6 inch risers (4 up and 2 back) on mine and it was really comfortable to ride.
Old 11-25-2006, 08:41 PM
jbt's Avatar
jbt
jbt is offline
Hey, 245... Great looking bike! Is that an 18 on the back? As you can see, I did a similar look on mine, but with 16's front and rear. I like that rear fender, too.
ORIGINAL: NightTrain245
ORIGINAL: Sidehack
[IMG]local://upfiles/8819/8B947044D76B48B2A6C6272EADB9DB40.jpg[/IMG]
Old 11-25-2006, 10:03 PM
Soul_Cal's Avatar
Soul_Cal
Soul_Cal is offline
JBT - Thanks ..... I have 18's on the rear and 21's on the front. If I had to do it over again, I may have gone the same route as yours. I like that fat front tire look.
Old 02-22-2007, 04:02 PM
Chapa's Avatar
Chapa
Chapa is offline
Stage IV
Phat Train, who makes the bars on your train? I really like that set up!
Old 02-22-2007, 06:44 PM
monkyman's Avatar
monkyman
monkyman is offline
I used Wild 1 chubby bars w500, internal wired, stock cables & brake line on my 05 Night Train. Probibly only a 3-4 inch difference in pull back, and a little wider than stock.
[IMG]local://upfiles/1358/A3BB3F8D47D2431A90101B66961EA566.jpg[/IMG]
[IMG]local://upfiles/1358/3B95E4BACE7549018708B73E60C10DBD.jpg[/IMG]
Quick Reply: Handlebar Options for Night Train
