98 starting issue
Old 07-14-2005 | 02:20 PM
lilbastard23456's Avatar
lilbastard23456
Stage I
Default 98 starting issue
I was enjoying a nice long ride when the ignition quit on me.... road side check revealed no spark to the plugs. The engine harness continuity checked good, and I ended up replacing the coil and ignition module. Now there is spark to the plugs, but still can’t get ignition.
(yeeessss – I did manage to check the fuel levels and shutoff valve position)
Any tips on what other items to test / check? Would the cam sensor or VOES keep it from starting?
Old 07-14-2005 | 06:05 PM
HDF Tech's Avatar
HDF Tech
Default RE: 98 starting issue
How about your vacuum operated fuel petcock if you have one? Did you draw a vacuum and check if you get any flow? What about the vacuum line to it also? Cracked/broken?
Old 07-15-2005 | 12:27 AM
mikeisglidn's Avatar
mikeisglidn
cam sensor will definitly keep it from starting
Bcoish
EVO
11
04-29-2019 09:09 PM
Scottyxbones
EVO
15
07-19-2018 04:51 PM
jmd897
06-08-2017 10:58 AM
jmd897
Engine Mechanical Topics
06-04-2017 11:14 AM
Dworrakk
04-04-2006 12:07 AM
Quick Reply: 98 starting issue
