q on stuck shock bolt
Old 09-10-2011, 01:13 AM
m i k e's Avatar
m i k e
m i k e is offline
Default q on stuck shock bolt
ok got bike jaked up,
2 shock bolts on back (toward rear tire)
1 comes off like a breeze ( 1 closest to belt pulley)
other bolt (closer to rear brake rotor) is a biatch
hints on how to get sumebitch outta there?
bike is 08 softtail
thanks
Old 09-10-2011, 01:14 AM
m i k e's Avatar
m i k e
m i k e is offline
oh yeah after i get 2nd bolt out is shock going to compress and smack me?
Old 09-10-2011, 01:34 AM
micahpop's Avatar
micahpop
micahpop is offline
If you had a little torch to heat up the bolt head, it might help to break it loose. It took me a long time to remove that bolt also because of the oil line that is right in the way. I could only move my wrench like 1/8" at a time.
No, the shocks are not going to smack you.
Old 09-10-2011, 01:37 AM
Kowan's Avatar
Kowan
Kowan is offline
Do you have a bottle jack you can place under the rear tire to support it once the bolt is removed?
Or use lumber or something high enough support the wheel. Being able to raise or lower the wheel/swing arm will make removal of the old and installation of the SAS easier.
I used a box end 3/4 wrench and while applying pressure, tapped the wrench with a rubber mallet to break the bolt loose.
I recommend anti-seize on the shoulder of the bolts once you are reassembling it.
Red loctite on the threads.
Since the SAS is a single unit like the ShotGun, you might not need the washers on the rear bolts. The Shotgun doesn't need them.
Old 09-10-2011, 01:43 AM
ptw***'s Avatar
ptw***
ptw*** is offline
Have read somewhere on the forum a recommendation to raise bike, position wrench between bolt & floor, lower bike & the bike will loosen bolt.
Old 09-10-2011, 01:48 AM
Kowan's Avatar
Kowan
Kowan is offline
Mine was so tight, that would have just tipped the bike over on the floor.
Old 09-10-2011, 07:57 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Heat it. Also, a 3/4" gear wrench from sears will really help as you won't have to continually take it off the bolt and turn it. They make one that has the optehrs ide of teh wrench turned the otehr way so it is really easy to get extra leverage. I would use that and smack it with a hammer or mallet until it loosens. I think this wrench only comes in a full set. The lowering teh bike onto the wrench to loosen is a good option too. Smart!
Another option is to use a piece of pipe or an old set of bars on the wrench for extra leverage.
Good luck!
Drew
Old 09-10-2011, 08:03 AM
jreichart's Avatar
jreichart
jreichart is offline
Box end wrench and a BFH !
Old 09-10-2011, 08:05 AM
m i k e's Avatar
m i k e
m i k e is offline
thanks guys i have it loose i just cant get it out yet!
drew is that a all in 1 shotgun?
i m buyin the next round for ya'll whatta have?
Old 09-10-2011, 08:16 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The compressor is a separate piece but the rest is all in one.
Drew
Quick Reply: q on stuck shock bolt
