I think you can run the heartland plate that mounts to the foot peg. You can probably run their side mount that attaches to the swing arm, and attach to the top portion of the swing arm as well. Give them a call to make sure.
Talk top Jake or Josh. (310)822-2697. Tell them I sent you please.
thanks to both of you guys, ill check them both out..
hspring, the one your using looks similar in design to the kurakyn one.. ive never seen either up close... do you know if kurakyn one is designed in such a way that you couldnt mount it to the upper part of the swingarm
The one thing to consider on the swingarm mounted plate with duals is that the swingarm moves independently of the pipes as the pipes are mounted to the frame and the swing arm is a separate entity. Just a thought.
When your rear end is aired out, do you think a sidemount attached to the swing arm would hit the exhaust?...
I just hate doing things twice, so im trying to take all things into consideration before buying them lol
Thanks again guys
I think it depends on where it is mounted. My concern would be the amount of travel in the swing arm while moving and hitting a big bump. I avhe not done any testing on this as I was in the same boat as you and no one had any answers for me.
