low budget lowering
I used 2 chrome lugs and a few 1/2" flat washers. It was under $10. How much you lower you bike is determined by how many washer you use. You won't need to remove your shocks to install this. But, you will need to reset the dampening on your shocks after the install. Which you will need to do after installing any of these kits. Also remember that as you adjust the shocks, it will raise your bike some too!
God bless!
Scott
God bless!
Scott
i bought the lowering kid bolts from ebay! dropped the bike 2 inches, or around there...
Looked great, rode like **** (as would anything that you basically completely compress your suspenion) but looked great... did i mention that?
i have samson true dual fish tails and they started dragging worse, obviously. Then added a 21' front wheel which changed the rake of the bike some more.
Needless to say i had to raise the bike back up for safety reasons, and so i could actually ride my woman around without my pipes permanently scraping the ground! haha
oh yeah, i give the cheap lowering bolts a +1
Mine bottomed out also after installing my lug nuts and washers, but YOU HAVE TO adjust your shocks after any lowering kits are installed. My shocks were on the softest setting before and they would bottom out when I hit a hard bump.
While your under there and have everything loose anyway. Go ahead and set up the shocks. I turned mine 5 rounds to bottom them out at the stiffest setting and then I backed it off 1 round. It rides better than it did before I lowered it.
God bless!
Scott
God bless!
Scott
Lo Boy Mods
I used a kit from http://www.softailloweringkit.com/ and it lowered my wife's Deluxe about 1.5" without sacrificing rideability or comfort. It was quite simple to install and you DO NOT have to remove the shocks to do it... Check out their video!
Just Say'n
You can Take these parts and follow the directions from the kit and achieve the same thing. You wont need the washers, i was trying something and it didn't work out. Just remember to Adjust Your Shock Dampening or you'll bottom out.
I hope that this helps you out.
God bless!
Scott
http://www.shotgunshock.com/
