Engine pings
Engine pings
08 FatBoy-stock 96 motor/intake/exhaust. When riding down the highway or passing, when I crack the throttle hard I hear a few clicks or pings coming from the motor. They stop when the RPM settles out. Only happens when running in a higher RPM range and the motor does not seem to be losing any power. It's done this as long as I've had the bike (1.5 years). I run premium fuel, 91 or higher if they have it. Comments...
My 07 Luxe does the same thing. Has stage 1 on it. I took it to H.D. last week to run it on the dyno to see whats going on with it. The Tech told me its common to have slight ping and the computer is suppose to take it away after a couple seconds. Sounds like B.S. to me but he ran it and printed out the results. Every thing looks clean. It still pings on excell in high gear. Hasnt burned down yet. Run it.
Stone
Stone
"Front and rear coils fire each spark plug independently (one
cylinder at a time - no wasted spark). The coil also has an
extra terminal to monitor current on the coil secondary circuit.
This is used for knock detection and combustion diagnostics."
Reasons for pinging/knocking could be:
- a too low fuel octane rating
- faulty or incorrect spark plugs
- too much carbon deposit in cylinder or on the piston
- ignition timing being advanced due to wrong sensor inputs from the Manifold Absolute Pressure Sensor (MAP) and/or Crankshaft Position sensor (CKP).
even a stock bike will ping. my bike was so lean the headers glowed cherry red after a night ride!! in stock trim, it only had 2000 miles on it when i noticed! the only way i got rid of the pinging was to go stage 1 and retard the timing in the area that i was exp. the pinging and richen the a/f. after that my pipes stoped glowing and the bike ran so much better!
No BS. The ECM monitors the combustion based on the various sensors on the bike and continuously adjusts the timing of fuel and spark. If pinging/knocking occurs the ECM will adjust to prevent it.
Stone
