08 Crossbones springer went soft...
08-24-2011 | 10:46 PM
How does one make the suspension stiffer? Is there an easy adjustment?
Thanks
08-25-2011 | 08:01 AM
Yup.... The shock preload from the factory is set reeeal soft. Just turn the lock nuts out and adjust the shock bolts
08-25-2011 | 08:25 AM
Rotate each shock 3 turns that should be plenty.
08-25-2011 | 01:05 PM
How about the front suspension? mine seems soft also.
08-25-2011 | 06:35 PM
Mine has softened up quite a bit also
ShadowforNow
12-23-2015 05:22 AM
kiltedchef75
10-10-2008 04:49 PM
nemick
08-16-2008 11:45 AM
nemick
07-29-2008 05:20 AM
ckamin
06-06-2006 01:34 PM
