88 Softail oil gushing through breather til empty
FXSTC has been sitting for a year. Started and spewed oil from the breather. Read all of the related posts in this and other forums and did the following:
Emptied the Sump
Rebuilt the oil pump
Replaced filter and all of the hoses
Confirmed routing of hoses correct and no kinks or blockage
Filled the tank a half quart low
Started up and oil again spewed from the breather. Emptied the tank completely. Refilled after again draining the sump and restarted. Opened the tank plug and oil is returning. Seems pressure quite high. Check valve and relief valve replaced on the pump rebuild and look fine. Bike has only 5,000 original miles on it. Any idea what could cause this? Could a vent be plugged somewhere causing too much pressure, perhaps in the rocker top?
Emptied the Sump
