screaming Eagle plug wires
Hi Everyone, got some of these from a friend, who changed his mind about fitting them, they were for his 07 Dyna, tried em on my 09 Fatboy and fit ok, rear slightly longer but looks fine, noticed that Harley list a different part number for the softail, am i right in assuming they will work the same? or could i do damage, only reason i want them is i think they look good in orange.
Its a different wire, not for your bike. I dont know about what damage it would do, but theres a reason for the difference, could just be fitment, who knows.
Pre-made Screaming Eagle plug wires are the same no matter which bike they are for. The only difference is the length. They are also not much better than stock.
Any set of plug wires will perform adequate up to 50 horsepower 5500 rpm limit. To help with the torque dip in the stock lean jetted motor or help overall with a higher output motor, check out spiral core wires. They will deliver much more spark to your plugs with a lot less leakage and have about 1/10th the resistance of standard carbon core suppression wires. Most peeps spend money without even thinking about it on bigger coils and then just buy the prettiest fattest wire they find (if they change wires at all) instead of putting something on there that will help deliver that spark all the way to the plugs.
