Heritage Headlight Options...
Have you tried adjusting them? The high beam might be aimed a little too high (lighting up trees more than the road) and the low beam might be aimed a little too low. Until you upgrade, adjusting the ones you have might give you some improvement.
I changed to this headlight:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
These passing lamps:
and this modulator for daytime use:
http://www.comagination.com/modulator.htm
I don't know how much brighter the LED setup is over what I have, but I'm more than happy with the light output .... lots brighter than stock, imo.
Whatever lighting system you use, make sure they're aimed properly cause they won't light up your world if not !!
Heritage Headlights
I have an "09 Heritage and I upgraded my headlights this summer. I bought 'Truck Lites" brand LEDs. If you google Truck Lites, you'll find a lot of info on them including a video comparing them to Harleys's LEDs. The conclusion that the video producers came to was that the Truck Lite brand LEDs had better visibility duting the day and from the side than the HD brand. Both are excellent during the night. I found a dealer in Illinois that had the cheapest price on line and my local indy matched that price. I believe Kuryakyn also sells Truck Lites. I paid a bit over $500 for the main beam and both aux lights, and if I had done a little more research on the aux lights, I could have saved another $40. I installed them myself in about a half hour. Flawless performance--absolutely no complaints on the lights.
I do wish I knew how the rewire the lighting system so the aux lights stayed on when I'm on high beam at night. That would really light up the road ditches
I thought about that and still might adjust the aim of the low beam a little higher, but it will also move the high beam up more as well. The low beam is pointed way too low. Lots of great suggestions here! Really appreciate them all. I think I;ll start with just a bulb change and eventually get the LED light. Not sure yet though.
Just be aware that old eyes don't see the bluer end of the spectrum as well as younger eyes. In fact, older eyes like the yellower end of the spectrum much better.
HID is a good option for old eyes as they are full-spectrum producers so if you get HIDs in the 4300*K you will get great light for older eyes. The 3000*K units are great fog lights (yellow).
1 Post
I am running Adjure Trillient cut tri-bar and black spot headlight and passing lamps on my Fat Boy. The headlight is a 35-watt 6000K HID while the side lights are currently bright white 4300K PIAA bulbs. Night vision is great but I will say that my headlight is not designed to properly reflect the HID light. I have an H3 HID kit for the passing lamps, but I have yet to install it because the wiring is too thick for the hollow nuts that hold the light housings to the crossbar.
mazz
05-22-2012 12:29 PM
