pass peg extension?
pass peg extension?
Wife would like peg extensions for the passenger pegs, would like them lowered a bit. She loves to ride, just isn't comfy with the stock setup. I have a stock 2003 Heritage, ann. edition.
Dealer wasn't any help.
Any suggestions would be appreciated.
Thanks for your time,
Steve
Steve
RE: pass peg extension?
Kuryakyn sells all kinds of different offset peg mounts, I'm sure you can find something that will work:
www.kuryakyn.com
www.kuryakyn.com
Depending upon your exhaust set-up, it may be hard to get the right side much lower. I used the Kuryakyn anti-rotation mounts reversed (left on the right and right on the left) and it will lower the pegs by about 3/4".
Perhaps if you move them forward it would help? I've used the Kuryakyn male mount lockable offset mounts (4") and the Kuryakyn lockable offset mounts (2") to relocate the pegs. I was trying to get them up and forward for Paula.
Since I'm changing my exhaust, I had to change the set-up. I ordered (should be here today! ) this kit from J&P.
If the J&P kit works out...I'll be happy to make you a good deal on the Kuryakyn parts...
ORIGINAL: Doug
HD Passenger Footboard Kits
Part #50602-00 $224.95
Doug
Doug
I was wishing they made a bracket for the passenger boards to lift them 2.5 inches...like the one they sell for the Touring bikes...[&:]
Just a note on fitment of the 360 degree rotating kits that J&P sells. I'm dealing with relocating normal pegs but, I'm pretty sure this applies to the kits for the 360 degree floorboards as well.
I ordered part number 5300260 which is a kit to allow 360 degreee rotation of the regular pegs. The parts look fine..I think the mount that comes with the kit will actually work in the "anti-rotation" department (why did H-D use only ONE bolt to mount the passenger pegs on softails?).
Only one BIG problem. They aren't a "bolt on" for '90 and up bikes. The mount uses a 1/2-20 bolt (it's got a threaded hole) to attach it to the frame and it MUST go in from the wheel side. My '04 uses a 3/8-13 bolt that goes in from the outside through the factory peg mount.
The J&P catalog says to use kit #5300261 for '90-'06 FLSTC's. This # is also for FXR's and, most importantly, after the tech person at J&P actually looked at the mount, it uses the 1/2-20 mounting bolt as well.
Basically, I have but two choices...send it back or drill and tap my frame for the 1/2-20 bolts. [&:]
You might also want to consider something like passenger mini-footboards. Even though in stock mounts, they "fit" your passenger's feet differently. Kuryakyn makes some; I imagine others do as well.
My wife loves hers. Bonus: They keep her boots off my pipe - mostly.
Hope this helps. - BrianK
