You could just check it after you put juice to the battery, see if the values are still inputed.. I dont think it would. The obvious tho, your bike would run like sheet.
I believe the settings are programed in flash memory in the module..........they won't erase unless you write over them. Removing the battery will not affect the program settings.
On a side note you might want to check the latest settings on V&H site. They update/change them occasionaly. The last update got rid of all my decel pop.
That's good to know..........my program is in from last winter. I get an occasional pop going from first to second if I jump it. Thanks for the update!
