Help keep my record perfect!!
OK guys I need some help, here’s the skinny. I have a 2002 FXST (carb). I am the original owner. I have the S&S IST ignition system, S&S carb, Vance and Hines Big Radius exhaust ( without baffles ). This past winter installed the gear drive kit with Andrews 37 cam, Feuling oil pump, lifters and cam plate, also adjustable push rods. Well the problem started with my bike blowing the accessory fuse, looked and looked and found that a wire had rubbed a small hole, where the wire from inside the handle bars comes out in the center of bars. Taped it and put some sheathing on it and that stopped the fuse from blowing again. I also replaced the horn and bought a new battery,( $130.00 for battery…..DAMN!!!). Now a couple of years ago I hard wired the garage door opener to the high beam indicator light, so when I pull up all I do is flash my high beam and garage door opens. Well here goes, My check engine light came on, bike ran and sounded crappy. Speedometer seemed to be off or maybe it’s in my head but it seems to register about 5-8 mph for a second when I’m actually stopped. Did some reading on this and thought maybe I need a speed sensor, so I bought one, installed it, cleared the code by doing the run off switch 50 times but the light came back on. I hate bringing bike to stealership in fact this will be the first time if we can’t figure this out. Sorry for such a long read, but I wanted to make sure you guys had all the facts. Help!!!!!!!!!
OMG!! Guess what? I posted this on another site,(copy-paste) I was spanked for my use of language. Some of the guys gave me other ideas to check so I thanked them and stated how I felt the words I used were not that bad...I have just been banned from that site for a week!! Talk about egos. Well I put a jumper on the data link connector and turned the ingition on. The check engine light turned on once for a couple of seconds went out for a couple of seconds then flashed twice. This seems to be the only code ....flash...flash, flash. Any ideas?
Pulled this from another site :
"= Invoking engine diagnostics on a < 2003 Harley =
To activate the diagnostic feature of the Check Engine Lamp, proceed as follows:
1)Turn the Ignition/Light Key Switch to IGNITION for three seconds (one second pause after the fuel pump stops running), and then turn switch back to the OFF (FLHTC/U-I, FLTR-I) or LOCK (FLHR/C-I) position for three seconds.
2)Repeat the instructions under step 1. above
3)Turn the Ignition/Light Key Switch to IGNITION and wait approximately eight seconds for the Check Engine Lamp to start flashing.
4)All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes. The lamp will then flash one or more times to indicate the first digit of the trouble code. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration. The second digit follows: following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5)If more than one trouble code is sent: following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off. Once all codes have been sent, the data string is repeated.
EFI Diagnostic Trouble Codes (DTC) and Fault Conditions
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low"
PS so what site got offended by "damn" ?
xraybox, thanks for that but I think you left out the most important thing. You have to get the data link plug and connect pins one and two in order for this to work. Went to the dealership and they said because I have the ist ignition module, their computer doesn't communicate with my bike, so I had to ask an S&S dealer to contact the company and ask them. The harley dealership said that the engine flashing meant nothing to them but it might mean something to S&S. My flashes were a 12, so I replaced my map sensor dissconnected the battery then cleared the code. Keeping my fingers crossed cause it did take a couple of days the last time I cleared it for it to rear it's ugly head. Praying to the Harley gods now. Oh and just so you know, the other site that thought damn and crappy were reasons enough to throw me out for a week was hdtalking. Oct.1949 no need to guess.....unless this doesn't work!!!
