Plug melting
Old 08-08-2011, 10:11 PM
Kowan's Avatar
Kowan
Kowan is offline
I replaced my stock sealbeam 35/55W with a 55/100W H4 on my old FXSTC.
No problems running the hotter bulb.
It does look like corrosion on the contact. Once connected, dielectric grease over the exposed connectors should keep it from happening again.
I'd also look at sealing the head light shell.
Old 08-08-2011, 11:25 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
I agree, but I would suggest you first make sure the connector fits tightly and put some dielectric grease on before you push the connectors together.
Put another thin layer over any bare metal after its connnected.
That way it keeps water out and helps conduct heat better.
Old 08-09-2011, 12:27 AM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
Another vote for a corroded connection at the wire and the terminal. Corrosion is "expansive" which means it takes up more room than the metal that is actually corroding. This loosens the crimp and spot weld junction that is used in the O.E. harness. The effective decrease in wire size as the corrosion essentially pry's the crimp open, generates a lot of heat, even with the current draw of a stock Headlamp.
Old 08-09-2011, 10:03 AM
1911NT's Avatar
1911NT
1911NT is offline
Thanks for all the info. I've been running a factory bulb same watts. I found my factory headlight with the harness that looks to be better quality. I'm going to splice and dice that plug in this week and I'll be sure to add some dielectric grease.
Thanks again!
Old 08-09-2011, 11:02 AM
If your going to splice the plug into the existing lines DO NOT USE cheap butt or crimp connectors.
They might work fine for a lot of different things, but they will NOT work for long on a bike.
The best way to connect two wires on your bike is to solder them together and waterproof the connection.
If you don't know how to do it right, and anyone else who might be interested.
Here's a link to a post I put up in the DIY section to show you how to do it so it will not give you problems later on.
https://www.hdforums.com/forum/softa...ml#post3307100
Good luck and ride safe.
Bigge86
10-07-2017 11:00 PM
screamer56
10-25-2015 04:05 PM
honestbob
06-02-2010 07:50 PM
ecvjohnny
03-31-2010 05:53 PM
Rockyriver
12-29-2009 03:25 AM
Quick Reply: Plug melting
