Need validation one last time - slip-ons + stock
I know I've read this stuff a hundred times but want to make sure...
True or false (most of the time)?
Your average slip-ons (Cycle Shack Slash cut) installed on a stock bike with no Air cleaner mod does NOT need to be tuned.
RE: 2006 FXSTSI. I'm going nuts with the stock stealth mufflers. I feel like I am asking to get plowed on the highway without more volume in the exhaust to alert people I'm there. I have a spare set of slip-ons from another bike so threw them on tonight. Fired up fine and idled fine. I'm 95% sure I'll have no issues except maybe some decel popping. I will have a full Stage I done in the future. But for now, I'd like at least one person to be my 5% and give me a thumbs up that I'll be fine until then.
Thanks.
Thanks.
RE: Need validation one last time - slip-ons + stock
Cool. Saved $$$ on this deal too. CS slip-ons (with a Softail part no) would have run me about $200. Had a set from a Sporty that fit. It was a sunk cost, $127 shipped new, so essentially they are free. Gives me some volume until I can afford the full system.
Check your plugs once you get them on to see how your mix is. You'll know when you ride it pretty much if it's way lean or slightly lean. I have a carb bike so it's a matter of jet selection, but me personally... I'd remap if it can be set electronically to be spot-on.. I'd do the air-cleaner kit first though.. Then you've got the two bolt-on performance upgrades done.. finito.
I did the HD Pro Torque slip-ons........racing. Added the A/C and went with the HD "race download". After 3000 miles, mine is running great, temp is good and the plugs look great. Decel popping is not a problem with my setup. Runs great, sounds great.
My only suggestion, make sure you get the proper download if you go that route.......the wrong one and look for issues.
Just my experience, goodluck!
