Softail Shock adjustment
Old 11-14-2006, 02:00 PM
bh73's Avatar
bh73
bh73 is offline
Default RE: Softail Shock adjustment
I can't believe how tight this one stubborn shock is. This is on a new heritage. I sprayed with wd40 and it still won't budge. The piece of chit hd wrench just bends and slips out. I have a couple of busted knuckles to show for it. The right shock turns fairly easy though. Just for kicks, the shocks do adjust in the same direction and are not opposite thread right? Thanks for all the help!
Old 11-14-2006, 05:45 PM
firemankrug's Avatar
firemankrug
firemankrug is offline
ORIGINAL: bh73
Yep, same direction on both shocks. Mine adjusted with no problems using the Harley wrench, sounds like you got a tough one.
Old 11-14-2006, 09:19 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
Just for grins, try going the other way FIRST. That way if there is something, dirt, rocks or the odd cat parts, stuck in the threads you should be able to dislodge it and flush it out with some WD-40 or something like it.
Old 01-01-2007, 12:09 PM
tmitchellof PG's Avatar
tmitchellof PG
tmitchellof PG is offline
ORIGINAL: bh73
I was trying to adjust the shocks on my heritage but one of them is very stubborn and won't budge. I loosened the jam nuts and was able to turn one of the shocks but the other one bends the spanner wrench when trying to adjust? Any tips on freeing up the stubborn shock?
Did you ever get your shocks adjusted?
Tom
Old 01-01-2007, 01:54 PM
UltraBrian's Avatar
UltraBrian
UltraBrian is offline
bh73: Just curious, but are you trying to lower the rearend? If that's the case, I may try it on mine.
Old 01-01-2007, 01:59 PM
springerGT's Avatar
springerGT
springerGT is offline
Which way do you turn them for a softer ride, mine bottoms out if I hit a cigarette butt.
GT
Old 01-01-2007, 02:23 PM
tmitchellof PG
I haven't adjusted mine yet ,so I don't know if it is set hard or soft. I am happy with the current setting, but will no doubt mess around with it to see what the difference feels like.
The manual says that turning the adjuster plates out (toward locknut) increases spring preload, to carry a heavier load. The manual doesn't state how many turns there are from softest to hardest setting. How many settings ,if any are there between soft and hard?
I don't have the required spanner wrench. I found a heavy duty spanner wrench on this site doing a search, that I will order in the next few days.
http://hometown.aol.com/jqdw/tailwrench.html
Tom
Old 01-01-2007, 07:37 PM
chester1957's Avatar
chester1957
chester1957 is offline
Adjusting spring preload does not lower bike, it stiffens or softens the ride, sometime after you lower a softail, you need to adjust the preload up to keep it from bottoming out. Mostly heavy riders, two up, and loaded down for long trips.
Old 01-01-2007, 08:26 PM
chilango13's Avatar
chilango13
chilango13 is offline
By adjusting the shocks, how low will the moto go--inch and a half? two inches? How low can you go?
Old 01-01-2007, 08:30 PM
chilango13's Avatar
chilango13
chester, i didn't see your post before i asked my question, but i guess you answered my question. Anyhow, what is one way of lowering a bike? thanks.
Quick Reply: Softail Shock adjustment
