All Lights flash when bike is off
Old 08-02-2011, 12:54 PM
brak4222's Avatar
brak4222
brak4222 is offline
The only other thought I had is that maybe the bike is throwing you an error code. Check all your bulbs first, but maybe it may wind up being an issue to be fixed under warranty.
Old 08-02-2011, 04:25 PM
jed1069's Avatar
jed1069
jed1069 is offline
Originally Posted by Wsucoug102
I changed out switch housings so had to mess with those things but did not change them
I would pull those back apart to make sure nothing is pinched.
Old 08-02-2011, 05:39 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
Sounds like auto arm is set and something is setting it off. Only a guess but definitely alarm related.
Old 08-02-2011, 06:33 PM
rockerz's Avatar
rockerz
rockerz is offline
don't quote me, but i believe there is a switch on the kickstand that has to be satisfied at a certain position.
Old 08-03-2011, 12:00 AM
av8or's Avatar
av8or
av8or is offline
Sounds like you've got a pinched wire in the switch housing. Maybe wires got pinched together and a turn signal when it flashes is powering your ignition or something. If that happens the current draw might not let the security system be satisfied, and it might continually go off.
Old 08-07-2011, 11:08 PM
CLSKIP's Avatar
CLSKIP
CLSKIP is offline
Default Fatboy lo electrical problems.
I have a friend that has a 2010 fatboy lo. His lights started going crazy. Happened mainly when he was running but it did it a couple times when it was shut off. Dealer thought it was the security module. Turns out the wiring that runs from back under the fender to the tail lights is no longer run through clips under the fender. They have it in a tube with double stick tape. Of course after riding in rain, and the big time heat it dropped down and the tire rubbed off the protective tube and the insulation on the wires creating shorts. Maybe check for that too.
Old 09-08-2022, 08:15 PM
lpkesler's Avatar
lpkesler
lpkesler is offline
Stage II
Did you ever figure it out. Currently having the same issue.
Old 09-09-2022, 09:07 AM
YZR's Avatar
YZR
YZR is online now
Received 1,952 Likes on 986 Posts
OP hasn't posted anything in 11 years...
Explicit_Spade
Electrical/Lighting/Alarm
07-12-2018 05:16 AM
robo74
11-25-2017 10:36 PM
Sparky07
03-18-2017 08:16 PM
bulldog82098
02-13-2015 10:44 AM
jmv
03-26-2012 09:31 PM
Quick Reply: All Lights flash when bike is off
