Rubber Remover
07-30-2011 | 04:55 PM
Rubber Remover
Does anyone have a good solution for removing boot rubber from my crome pipes? Yes my wife rested the heel of her new boot on top of the pipes.
07-30-2011 | 07:58 PM
My wife does the same thing. I usually just wait for a time when the pipes are hot and wipe it off with a rag. Hot enough to melt on, hot enough to wipe off.
07-31-2011 | 04:22 PM
a friend of mine uses windex and tin foil yes tin foil. It scraches the pipe a little bit though. Just spray on and rub it takes a little while.
07-31-2011 | 04:25 PM
I've heard of people using a real copper penny on them before (to scrape it off), but I've never tried it.
07-31-2011 | 04:48 PM
get the pipes hot and wipe it off
07-31-2011 | 05:01 PM
I have that problem also. Too lazy to lift my feet out like I should I guess. I use Turtle Wax chrome polish and a little elbow grease with good success.
07-31-2011 | 05:08 PM
+1 on gettin it hot, you can use some 0000 Fine wool also. LIGHTLY, when its hot
07-31-2011 | 05:37 PM
Oven Cleaner works well without scratching the chrome. Follow the directions on the can as if you were cleaning your oven.
07-31-2011 | 06:28 PM
I've used a nickel or penny without any kind of damage. I've also used an old credit card once the pipe is warm.
07-31-2011 | 06:37 PM
The MoCo sells a boot mark remover for pipes. Squeeze some on, let it sit and buff it off.
