Rear brake light switch
So, noticed this morning that my rear brake does not light the brake light. Front does just fine. Here is what I was thinking in order of checking things out...any other ideas certainly welcome as I tend to miss the obvious!
Brake fluid level in rear master
2 ( I believe) connectors connect to the switch
See if current when brake is applied, but I dont know which connector should have power....hmmm
Then if those are good. Replace the dadgum switch and bleed the brakes
